Dick Axtell
posted on 8/3/16 at 04:14 PM |
P.W.S. Loom Q
Hi Everybody,
Those of you who have used a PWS loom may know this. In the engine loom, there is a black cable to connect to the ignition coil. Is this a constant
12v supply, switched on via the ign key?
Am still sorting out which cables have to connect to the Nodiz (white) plug.
posted on 8/3/16 at 06:11 PM |
I thought you had managed to get hold of a copy of the wiring "diagram", it should be shown on there. If you haven't got a copy it
might be able to help if I can find mine.
tims31
posted on 8/3/16 at 10:16 PM |
I asked the question of Alan when fitting mine and he said to the switched ignition. On mine I have it going from switch live to IGN on the alternator
- Nipon Alt with two pins one IGN, one L
HTH
The instructions just say "using the black wire to connect to Coil Positive or Ignition pack"
[Edited on 8/3/16 by tims31]
Build: http://www.martinsfurybuild.co.uk/
Dick Axtell
posted on 9/3/16 at 09:34 AM |
Thanks for your replies.
RustyNuts - Yes thanks, I got the pdf copies of the PWS crib sheets, which i.d. the various cables in that loom. I merely asked if the coil supply was
uninterrupted, whilst the ignition switch was on. Can't see why it wouldn't be, just wanted to make sure.
Tims31 - Noted your quote - The instructions just say "using the black wire to connect to Coil Positive or Ignition pack". That
clarifies things.
[Edited on 9/3/16 by Dick Axtell]
posted on 9/3/16 at 02:26 PM |
Glad you have it sorted.
