rash12
posted on 9/3/16 at 08:33 PM |
vicki green loom problem
in need of a bit of help with the vicki green loom, sierra headlight circuit need to know where the white wire is connected to that feeds a 20 amp
fuse that feed pins 87 and 86 on both relays if i connect this to battery it all works but no control on the headlight switch so i assume it connects
to the switch somewhere but dont appear to have any spare wires any help appreciated
thankyou
snowy2
posted on 10/3/16 at 09:40 AM |
Pin 87 is an output from a relay....pin 86 is one of the two trigger wires......if you expect the relay to work via those two wires ....it
won't. ...pin 85 and 86 to trigger the relay. .pin 30 and 87 for the output.....
sometimes you are the pigeon, most of the time the statue.
rash12
posted on 10/3/16 at 04:15 PM |
thanks got it sorted the drawing isnt the best but one of the sparkys at work managed to decipher, he said did a child draw it, lol
