Sierra
| posted on 19/3/16 at 03:05 PM |
Savage switch wiring
Right just wondering if anyone can help. Everything was working fine in the summer but when I went to take it out now I found that the fuse would blow
when turning the side lights on. So if I press the button once for side light fuse blows, press it again and low beam comes on as normal. All but side
lights still work but the back lights no longer work on the switches. I took the dash off and accidentally disconnected a few wires to the switches.
Connected back where I think they went but then found that the stop button didn't work. Ordered new switch block and stop button now works but
side light still blows fuse. Bought a load of fuses off eBay to find that they don't blow but melt :0. Put a 10a fuse in for side lights, press
button only to see smoke from the red wire going from start button to stop button. Fuse melted!
I've drawn out how the switches are wired up below, can anyone see an issue which may cause this issue.
[IMG]http://i50.photobucket.com/albums/f340/s18rra/DASH%20WIRING_1.png[/IMG
[Edited on 19/3/16 by Sierra]
Sierra
| posted on 21/3/16 at 02:20 PM |
There must be some auto electricians on here
ste
| posted on 30/3/16 at 10:15 PM |
On your start button, you have got a live and ground on pins 2 & 3 on the bottom part of the switch
Why?
It doesn't make sense, unless you have connected them to 1 & 2, in which case you have got a direct short to ground.
Your wiring diagram doesn't really have much info in it, but that's the most obvious.
Sierra
| posted on 31/3/16 at 06:46 AM |
Thanks for the reply.
I've actually sorted it all now. I literally started a fresh and all is working
