Author: Subject: Crank Sensor Connection?
Dick Axtell
posted on 21/3/16 at 06:35 PM Reply With Quote
Here we go again!
Still trying to finish soldering joints between existing loom and the Nodiz plug. Where should the crank sensor wiring shield be connected?
[Edited on 21/3/16 by Dick Axtell]
mackei23b
posted on 21/3/16 at 07:28 PM Reply With Quote
Hi there
Normally back to the ecu Earth.
Ian
posted on 21/3/16 at 07:35 PM Reply With Quote
On mine the shield went back to connection on the edis.
Dick Axtell
posted on 21/3/16 at 08:33 PM Reply With Quote
Guys, thanks for your replies. I had expected that the shield part of the Nodiz sensor cable woulkd have to go to earth - but where? The Ford wiring sensor connector plug doesn't allow for an earth.
So, to connect back to the ecu would leave some of the cable unshielded, which seems contrary to the Nodiz installation guide.
Coozer - The Ford coil pack has only 3 wires, none of which provide an earth. By "edis", are you referring to the Ford module? E.g. as in http://www.locostbuilders.co.uk/forum/34/viewthread.php?tid=203155
posted on 21/3/16 at 08:47 PM Reply With Quote
It is normally should only connected at ONE end the reason for this is you have a main engine earth cable problem all the starter current will try to flow through it.
Altough the sensor outputs an AC signal sensor also has polarity.
ISTR the coil pack earths through the case mounting.
[Edited on 21/3/16 by britishtrident]
Dick Axtell
posted on 22/3/16 at 12:33 PM Reply With Quote
Clarification from Alex at M-E.
"The shielding only connects to the Nodiz side. The sensor side is to be left unconnected."
That confirms it. No earth necessary, just keep the shield as close as possible to the sensor connector. And 1 step closer to finishing the electrics.
[Edited on 22/3/16 by Dick Axtell]
