Author: Subject: Ignition Switch Wiring
JamesyCottony
posted on 25/3/16 at 08:17 AM Reply With Quote
Hi there,
Looking at the old ignition switch:
Im trying to work out which wires go where on the new one:
Im guessing White is IGN (Ignition)?
Light Green/White is ST (starter)?
Brown is BAT (Battery)?
Red/White is ACC?
[Edited on 25/3/16 by JamesyCottony]
ken555
posted on 25/3/16 at 10:02 AM Reply With Quote
http://www.mgb-stuff.org.uk/colourcodes.htm
Assuming standard Lucas scheme
Brown main battery feed, unfused
White +Red Solenoid starter switch to starter
White Ignition control circuit
[Edited on 25-3-16 by ken555]
JamesyCottony
posted on 25/3/16 at 11:49 AM Reply With Quote
Thanks, so Light Green/White goes to Accessories?
ken555
posted on 25/3/16 at 12:42 PM Reply With Quote
The White + Green should be the fuel pump circuit.
Connect the other and see what doesn't work then you will know.
JamesyCottony
posted on 25/3/16 at 03:25 PM Reply With Quote
its a mechanical fuel pump, so has no wiring
snowy2
posted on 26/3/16 at 06:51 AM Reply With Quote
it will take all of 5 minutes to find out using a multimeter........that way you will know for sure....
sometimes you are the pigeon, most of the time the statue.
