the_big_1
posted on 25/4/16 at 09:17 PM |
Connectors Identification
Hi Guys,
In the process of designing my wiring.
New manifold has arrived today, two connectors I am stuck on what they are for if you guys could help.
One is a two way (Very Top Connector) with the wire colors: White / Violet and Brown White.
Other is a one way (Top Right Connector) with wire color: Black / Orange.
Guys
big_wasa
posted on 26/4/16 at 05:29 AM |
Top one looks like the coolant temp sensor. Late black top is in the head not the thermostat housing like earlier zetec's. You will need to
move it to the thermostat housing and change the plug.
Bottom one being a single pin will be the low oil pressure switch. Again different plug to a silver top.
snowy2
posted on 26/4/16 at 07:02 AM |
if you decide to remove the coolant plug to replace it for a mondeo one, i would buy it from you....my car had it cut off and i am looking for one.
cheers Dave.
sometimes you are the pigeon, most of the time the statue.
posted on 26/4/16 at 07:54 AM |
I've found Vehicle Wiring Products very useful and helpful for connectors and wire etc.
http://www.vehicle-wiring-products.eu/
