tom_loughlin
posted on 25/12/04 at 06:45 PM |
Wiring Diag.
does anyone happent to have a wiring diagram for a 1.8cvh sierra powered locost (or similar) because im going round in circles with my premier wiring
systems loom instructions, mr Haynes wiring diagrams, and the 'book' diagram...
i knew the electrics would be my least favourite part.
so far, all ive really done is wire up the ignition, and the coil.
cheers guys,
Tom
mookaloid
posted on 25/12/04 at 08:54 PM |
I found Alan at Premier very helpful when I got stuck.
The instructions started to make sense after he gave me a few hints - like where to find the terminal numbers on the column stalks etc.
In fact if you lay out the loom on the floor, then label the various sections, instruments, column switches, engine, front and rear looms etc, then
start by placing the behind the dash bit so that the instrument and steering column switches reach nicely, the rest seems to follow.
treating each section separately makes it much easier.
Also identifying which type of column switch you have (there are two types) is another good thing to sort out early on.
HTH
Mark
[Edited on 25/12/04 by mookaloid]
