Author: Subject: Speed sensor pickup - Diff and Prop?
Banana
posted on 2/11/16 at 10:59 AM Reply With Quote
Hopefully fitting my clocks this weekend..
can someone clarify if CBR speed sensor works from bolt heads, or must it be magnets?
If im using a speedo healer, can i run it from the driveshaft as oppose to the prop?
thanks
Toprivetguns
posted on 2/11/16 at 06:48 PM Reply With Quote
I've used my speed sensor on the prop to diff bolts and calibrated with a speedo healer.
So far so good it work really well. Not sure about the CBR, but most sensors detect a magnet field. So either steel bolts or magnets will work.
Plenty of threads on here with useful tips.
Only drive as fast as your angel can fly... !
Banana
posted on 3/11/16 at 03:54 PM Reply With Quote
Sorry, you used it on the diff or the prop?
I did have a search, couldn't understand why people are using magnets if not required..
