Author: Subject: Blackbird ECU wiring.
Crash Test Dummy
posted on 25/12/16 at 09:42 AM Reply With Quote
My first post. Apologies for it being a request for help.
I'm working on a Honda Blackbird install. It's a carb engine.
The ECU has two identical wires side by side that are yellow with a blue trace. I know that one goes to the coils and the other goes to the TPS but I need to know which is which.
I think that the one to the TPS should be giving 5v with the ignition on but it isn't which hints at a fault with the ECU and isn't helping with tracing which wire goes where.
Does anybody have a pinout diagram please?
TIA.
Indybird88
posted on 29/5/17 at 09:38 AM Reply With Quote
Still needing help with This? I can check mine and report if you like.
L
Crash Test Dummy
posted on 29/5/17 at 05:48 PM Reply With Quote
Thanks but I sorted it out by trial and error. Luckily nothing blew!
