Author: Subject: Weather gear lights etc
carlknight1982
posted on 12/2/17 at 09:10 AM Reply With Quote
Due to a change of circumstances it looks
Like I get to keep my car However I will need to make it more useable so I'm looking at windscreen ideas and heaters and better lights as I will be using it more at
Night
Any recommendation ?
Logic will get you from a A to B
Imagination will take you everywhere.
voucht
Contributor
Posts 237
Registered 22/5/11
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 12/2/17 at 07:12 PM Reply With Quote
It might not be the cheapest option, but an easy one: GBS Zero parts might fit your car, as it has the same width as our Haynes Roadsters (same width).
I personally have an aero-screen from them, and it fits perfectly. I guess it is the same foe their windscreen (you might have to adjust the lower edge to your scuttle), and their rain gears.
Hope that helps
http://www.kitspares.co.uk/index.php?route=product/category &path=43_21&car=43
[Edited on 12/2/17 by voucht]
https://vouchtroadster.blogspot.com/
https://cafrazx550.blogspot.com/
