SJ
| posted on 17/3/17 at 01:02 PM |
Brake Light Switch
I'm about to replace my hydraulic brake light switch with one operated from the pedal but can't think of an easy way to operate it given
the pedals are floor mounted.
The switch is the type that attaches to the pedal with a spring which then pulls the switch to make the circuit. Maybe I just have the wrong switch
but if anyone has any great ideas for floor mounted pedal switches I'd be grateful!
I've had a quick search and can't find a definitive answer.
Stu
CosKev3
| posted on 17/3/17 at 01:50 PM |
I've used a mini switch,and made a bracket up to mount it with a tab welded onto the pedal to operate the switch.
loggyboy
| posted on 17/3/17 at 02:01 PM |
I had considered using a long arm microswitch behind the pedal for this, should allow it to trigger, and still flex when pedal is pressed further.
Straight Hinge Lever 3 Pins Basic NO NC Momentary Micro Switch 2 Pcs T8
[Edited on 17-3-17 by loggyboy]
Mistral Motorsport
CosKev3
| posted on 17/3/17 at 02:31 PM |
Think Rosco used a similar thing on his Haynes
Rosco86
| posted on 17/3/17 at 03:00 PM |
here is my solution, its on this page
http://www.locostbuilders.co.uk/viewthread.php?tid=194553&page=12
i put the switch up top so its easy to get to and adjust if needed
My Build Thread
Rosco86
| posted on 17/3/17 at 03:02 PM |
beat me to it!, as above, i had the switch held shut all the time then any pedal movement triggered the switch
My Build Thread
SJ
| posted on 17/3/17 at 05:15 PM |
Cheers Rosco86, that is exactly what I was looking for.
Just got to try to copy it now
Suffice to say my car isn't built with the same attention to detail or skill as yours.
[Edited on 17/3/17 by SJ]
Ianboom
| posted on 13/4/17 at 08:16 AM |
I bought a hall effect sensor from China (£1.80) that works when the pedal is within 4mm. I had to install it with a spring on its mounting, so If I
lost pedal pressure and the pedal travelled further it wouldn't jam the pedal up.
Only downside, was I had to fit a relay to handle the current of the brake light bulbs.
Angel Acevedo
| posted on 9/3/19 at 02:25 AM |
Hi CosKev3.
Planning to do something similar. How intrusive is the solution when driving.
Something you would have done differently?
Thanks.
CosKev3
| posted on 9/3/19 at 11:54 AM |
Hi CosKev3.
Thanks.
No doesn't interfere at all,due to the angle of the pedal the switch is a good few inches away from feet.
Only thing I would do is make sure any debris/small stones etc can't get underneath it,I've had it happen a couple of times causing brake
lights to stick on.
Angel Acevedo
| posted on 9/3/19 at 12:24 PM |
Hi CosKev3.
Thanks.
lights to stick on.
Thanks.
My pedal box is a Compbrake unit and the pedal almost vertical in the stand by position so I don´t know how it ill be.
Ill make the arrangement and if it proves too intrusive, I´ll make a a floating Pedal Pad to actuate a smaller microswitch.
Best regards.
AA
Angel Acevedo
| posted on 13/3/19 at 03:25 AM |
Well, My contraption did not work,
I did not considered pedal position once the master cylinders and pushrods were installed. Now they are installed the actuating cam doesn´t even come
close to the switch.
So Angry grinder will be called upon to remove bodge...
I am moving to microswitch actuated at pedal face; if microswitch doesn´t last long, I´ll use a relay.
I hope I don´t need it as all my brake lights are LED units.
Will keep ypu posted.
| posted on 13/3/19 at 02:06 PM |
I used a hydraulic switch when I built my MK Indy a few years back. It did work, but if building again I'd use an electric switch, probably in
the same way shown above.
Angel Acevedo
| posted on 13/3/19 at 03:16 PM |
This very switch is the one I´m using.
Microswitch
It is not DC Rated but, if it doesn´t last, I´ll put a relay...
