johnH20
posted on 3/7/17 at 06:05 PM |
Is my battery realy dead?
Put my car away yesterday without realising I had left the lights on ( used as DRLs ). Flat battery this morning unsurprisingly. It is a PowerVamp 25
( Rebadged Odessy 680? ). Although it is 5 years old it has always appeared very healthy and will restart the car easily after a month of inactivity.
It now reads 4 volts and will not accept charge from my 'intelligent' charger. Is the charger not that intelligent or is the battery dead?
adithorp
posted on 3/7/17 at 06:10 PM |
Battery maintenance chargers don't like dealing with flat batteries so I'd say it's that and not the battery
http://jpsc.org.uk/forum/
pmc_3
I'd put a non-intelligent charger on it for a bit to get a bit of juice in to it and then swap back. Some of the intelligent ones won't
charge it if it's completely flat
coyoteboy
posted on 3/7/17 at 06:17 PM |
Just hook it up to a live battery/car for 10 minutes. Then try again.
gremlin1234
posted on 3/7/17 at 07:20 PM |
as above
or jump start it, then run for a few minutes, then the intelligent charger should be clever enough.
quote: Is the charger not that intelligent
normally they don't like charging below a few volts, to ensure they are connected, not 'shorted' or the incorrect polarity
edit, clarity ;-)
[Edited on 3/7/17 by gremlin1234]
perksy
posted on 3/7/17 at 08:13 PM |
You might be lucky with a re-charge
but in the longterm PC680's don't like being totally discharged, ask me how I found this one out
posted on 3/7/17 at 08:34 PM |
In the long term get special voltage sensing DRL relay that switches the DRL only when the alternator is actually producing more than 13 volts.
gremlin1234
posted on 3/7/17 at 09:28 PM |
or just when the engine/ignition is on
johnH20
posted on 4/7/17 at 05:55 PM |
Glad to report that the trick of connecting to another battery seems to have worked.Dead one up to 10 v in 20 mins and now charging happily. Whether
it will be good long term I do not know but thanks for the tip.
coyoteboy
posted on 4/7/17 at 08:44 PM |
In my experience you get about two goes at that process and then you're buying a new one. Glad to hear go number 1 was successful!
