Author: Subject: in tank fuel pump
ady8077
posted on 15/1/05 at 06:13 PM Reply With Quote
in tank fuel pump
Hi all
I've been looking for a inj fuel pump to fit in a surge tank for a future efi upgrade
Any recomendations?
Also how does an intank mount?
Thanks Adrian
posted on 15/1/05 at 06:25 PM Reply With Quote
It screws on the end of the suction tube which is usually part of the tank level sensor unit , Rover use them on some models. I think the 800 series has one held by a ring of small screws but the 200/400 use a Smiths bayonnet ring fitting.
Not sure about the 600 series.
The 800 tank unit is about the correct depth for a Locost tank --- easy to removeby unscrewing a plate under the rear seat.
ady8077
posted on 15/1/05 at 10:43 PM Reply With Quote
thanks
I hadn't realised the hole pump is immersed in the tank
I'll have a look
Adrian
Mix
posted on 16/1/05 at 09:57 AM Reply With Quote
Imprezza's also use an in tank pump.
Mick
posted on 16/1/05 at 02:13 PM Reply With Quote
I found an illustration of the Rover 600 unit I will scan it in later, it looks ideal, held on by 6 bolts both flow and return lines fit on to it --- flow has nice banjo fitting, suction has a nice sock filter. Fuel gauge sender is not part of unit.
Output at pump on a new unit is 0.23 litres in 10 seconds, max presure is 330 kpa
[Edited on 16/1/05 by britishtrident]
ady8077
posted on 16/1/05 at 04:26 PM Reply With Quote
Sounds good
Can you upload it here?
Adrian
posted on 16/1/05 at 06:26 PM Reply With Quote
ady8077
posted on 16/1/05 at 11:01 PM Reply With Quote
Thanks BT
I've printed it off ready for my trip to the scrappies
Do you know if its under the rear seat too?
Adrian
posted on 17/1/05 at 07:40 AM Reply With Quote
Accord to the book on the 600 the tank needs dropped, try an off the shelf breaker they might be glad to get rid of one 600 parts don't move fast because they are so reliable.
