bob
posted on 19/1/05 at 06:52 PM |
Twin vacuum distibutor ?
I've got a spare bosch electronic distributor for my pinto engine,the only problem is that its got a twin vacuum instead of the normal single
vac used on the pinto.
Any clues ?
The only info i have is that it may have once been on a pinto in a transit,BUT the dizzy came from a 2.1 pinto running 45's.
I just want to understand the twin vac bit,ie why it needs two vacuum pipes.
[Edited on 22/1/05 by bob]
posted on 21/1/05 at 02:28 PM |
Its a vacuum retard -- emision control dongle over retards the ignition to allow a higher throttle opening at idle -- a kludge to reduce emmisions
at idle.
bob
posted on 21/1/05 at 03:32 PM |
Thanks for that BT
I am going to sell it as its surplus to me,i just wanted to know why twin vac instread of the normal single pipe was used on this dizzy.
I'm sure if i advertise it people will ask the question
