Author: Subject: Furore headlamps
Stef7
posted on 16/3/20 at 07:55 PM Reply With Quote
Furore headlamps
Bought these headlamps but then I realised that the rubber does not really fit and the whole headlamp is not waterproof:
https://furoreproducts.co.uk/miniature-twin-projector-headlamps-LHD
Anybody had any experience? Have you seen any cases I could use for these lamps?
Or, any proven headlamps for kit cars that are not just regular Dominator lamps?
Thanks!
Mr Whippy
posted on 17/3/20 at 12:47 PM Reply With Quote
Personally I'd have a hole in the bottom of them anyway to let any water out Their going to get very hot inside and any moisture inside would be driven off.
Can you not use a little bit of silicon gasket sealant?
Stef7
posted on 17/3/20 at 01:28 PM Reply With Quote
Thanks, that is some idea with the hole for the water. I haven't thought about it this way, although slightly uncomfortable with with water and electric wirings.
russbost
posted on 17/3/20 at 03:34 PM Reply With Quote
The whole front end of those lights is entirely weatherproof, the rear end carries only the 12v feed wiring & hence the requirement for the protective rubber boot, the boots should be secured with a cable tie or cut down for a tight fit & can be sealed with silicon sealant if required, you have to make a hole in the boots for cable entry anyway & this should be at the bottom to allow for drainage.
