Deckman001
| posted on 4/5/20 at 07:59 AM |
Side Repeaters
Hi all,
I was just wondering what people have used for these, on my car built over ten years ago i fitted them suitable for the regulations at the time, now
for IVA i have to fit different ones in addition to the ones i have already fitted, but thankfully you can have more than one each side, so, where
did people put theirs? am trying to keep it locost, so Caterham front wing mounted ones are too expensive in my mind
Jason
adithorp
| posted on 4/5/20 at 08:43 AM |
I assume you've fitted them to the scuttle? That fails the angle of visibility check from the rear as the rear arch hides them.
Either fitting to the front edge of the rest arched (check they don't exceed the max distance from the front) or on the outer edge of the front
arches is the common solution. Little button ones are common and shouldn't be too expensive.
Don't think (not got manual to hand) you can have more than one each side do you'd have to remove the current ones. Just removing the
bulbs isn't enough AFAIK
http://jpsc.org.uk/forum/
ianhurley20
| posted on 4/5/20 at 08:53 AM |
I used cheap 1cm ish button ones from ebay and fitted them to the outside of front wings to get all the visible angles right. Only 1 set allowed or
required. Interestingly I used old VW Bettle indicators on the top of the front wings and they will get all the angles covered both front and rear, if
it didn't say I had to have repeaters I would not have needed them
CosKev3
| posted on 4/5/20 at 08:54 AM |
As above you are only allowed one set of side repeaters, you will need to stick a badge or summat over the holes whilst IVA'ing if you want to
fit them back to scuttle after test
Deckman001
| posted on 4/5/20 at 09:26 AM |
Damit, Ok guys, many thanks for the answers, I thought i could use both, but hey ho, another problem to resolve for not getting it sva's many
years ago.
Jason
| posted on 4/5/20 at 09:42 AM |
Wing mirror mounted repeaters would probably be OK but can’t say I’ve seen any suitable for a locost
Deckman001
| posted on 4/5/20 at 09:49 AM |
As you can possibly see them from the above pic, I mounted them along the sides, in between the front and rear arches so a definite no-no now.
So I'll have to try and track down the 10mm ones stated above and get them fitted to the front cycle wings instead.
Are you allowed a side marker light as a running light, always on while the lights are on?
Jason
40inches
| posted on 4/5/20 at 11:10 AM |
You may find it easier to wire if you fit them to the rear arches?
They need to be less than 2600mm from the front,if I remember correctly.
  Side Repeaters
Deckman001
| posted on 4/5/20 at 11:59 AM |
  Side Repeaters
Yep you are correct as usual , where did you get yours from ? I can only find ones that need a 20mm hole through the bodywork.
Jason
907
| posted on 4/5/20 at 01:50 PM |
Before IVA
And after IVA
Deckman001
| posted on 4/5/20 at 02:16 PM |
Before IVA
And after IVA
That's an interesting option.
I'll have to wait till i get it back before deciding which is the best looking option for my car, although that doesn't mean both options
are possible for my car as mirrors are different and I was originally thinking of side mounting on either front or rear arches firstly.
Hmmmm decisions decisions.........
Jason
40inches
| posted on 4/5/20 at 10:07 PM |
  Side Repeaters
Jason
They are the 20mm ones, I removed them from the rubber sleeve and fitted the light directly into the fibreglass
Around a 12mm hole.
CosKev3
| posted on 5/5/20 at 12:49 PM |
Jason
To give you some more to do you will need some bigger headlights too with a beam pattern.
Some people have passed with dominators, but majority fail IVA
Deckman001
| posted on 5/5/20 at 02:25 PM |
Jason
Ive got my MOT guy checking them while he sets the suspension, when i checked them inside the garage they showed a level beam, so i checked the IVA
manual and it says it must have a level beam or a kick up to the left, so hopefully the level beam will suffice.
Although I am open to being told by anyone who used them for IVA and failed ?
Jason
Deckman001
| posted on 5/5/20 at 02:35 PM |
  Side Repeaters
Jason
Around a 12mm hole.
Oh, i see !! that makes them even better for my decision as to where to fit them
Jason
CosKev3
| posted on 5/5/20 at 03:24 PM |
Jason
Jason
Pretty sure on the beam checker it wont be a defined enough flat beam, they are more of a 'blob' of light,because they are motorbike
headlights.
Also check the stated heights and width measurements in the IVA manual,with them being so small they dont meet the requirements on some chassis
without being spaced outwards or upwards
Deckman001
| posted on 5/5/20 at 04:09 PM |
Jason
Jason
headlights.
Yeah I have set them out with at least 50mm within the max distance from the outside and they clear the front wheels nicely too, I have had to raise
them by about 30mm so at to clear the min height too so hopefully the ride height won't be changed during the set up
Jason
Deckman001
| posted on 5/5/20 at 04:12 PM |
But all, please keep coming back with questions or queries regarding my build, I've not put a car through this sort of test before and first
built this car over ten years ago so am trying to play catch up with the rules and I expect to miss quite a few things so all help is very much
appreciated.
Jason
