Author: Subject: Fan control
Snuggs
posted on 9/5/20 at 11:14 AM Reply With Quote
Fan control
Anyone know the pin on an EEC-V (LAAN) ecu that is for the fan control relay.
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
big_wasa
posted on 9/5/20 at 01:14 PM Reply With Quote
Laan should me a mk2 Mondeo ( Blacktop ).
I think the high speed fan control will be pin 17 a black wire with a white trace ?
You will need the k46 5 pin relay for it to work for some reason. It has a diode in it between the fan out put and a separate chassis earth.
Snuggs
posted on 9/5/20 at 01:19 PM Reply With Quote
Cheers, I knew the oracle would have the answer.
big_wasa
posted on 9/5/20 at 06:30 PM Reply With Quote
It switches the earth.
You may also want to try pin 68 Black with a blue trace this is the standard fan control and may come on a few degrees sooner.
[Edited on 9/5/20 by big_wasa]
Snuggs
posted on 10/5/20 at 07:19 PM Reply With Quote
Marvellous, Any idea what temp it switches at ?
big_wasa
posted on 11/5/20 at 03:30 PM Reply With Quote
High speed was fairly high, 112degC from memory. I can't remember thr other one.
