Author: Subject: Lights question
tks
posted on 28/1/05 at 03:20 PM Reply With Quote
Lights question
i have ordered the tipical lights from england for my luego velocity,
bow i'm playing with the switches and i wondered that have those lights 3 beams in it?
i mean a normal car has 3 lights
Normal (very weak)
Dimm (Beam) normal driving
Big Straight Beam (Large...) driving in heavy rain etc..
does a kitkar also has those lights??
and wich of them are sva needed???
TKS
posted on 28/1/05 at 03:23 PM Reply With Quote
The 3 lights are:
Sidelight or Position Light (as the SVA manual calls it)
Main beam
Dipped beam
Yes, you need all 3 for SVA, but the sidelight doesn't have to be in the headlight unit (but it often is for a seven-type car, as it's convenient).
tks
posted on 28/1/05 at 03:27 PM Reply With Quote
ohh oowww...
and wich
unit do you advice...
from rally...site..??
i only find H1 bulbs... and thats a normal beam...
TKS
posted on 28/1/05 at 06:04 PM Reply With Quote
H4 bulbs for headlights
Make sure you get the lights dipping the right way for the Continent as well.
tks
posted on 28/1/05 at 11:27 PM Reply With Quote
yeah....
CIBIČ SUPER BI-OSCAR - Fog/Drive lamp
[CB82866] £59.50
Click to enlarge
The Bi-Oscar is a developed version of the Super Oscar with a single reflector to suit fog and driving lamp functions where only two auxiliary lamps are to be fitted. H4 bulb
will this one suit for europe??
where else could i find some usefull lamps??
TKS
Steve @ sVc
posted on 2/2/05 at 04:01 PM Reply With Quote
The lights usually fitted to the Velocity are 5 3/4" diameter and should have a 5w parking or side light, and a H4 bulb to give you dipped and main beams.
For Spain the lights will have to dip to the right hand side.
You can see these lights on our web site www.s-v-c.co.uk , in the headlight section.
The Cibie lights you have mentioned are auxillary driving lightrs and will not be suitable as the main headlights on your car.
Hope this is of assistance
Steve @ sVc
