Author: Subject: Compressor starting problems.
John Bonnett
posted on 6/1/21 at 06:51 PM Reply With Quote
My belt driven compressor has a single phase 3hp motor. A year or so ago the capacitors blew and I had the motor repaired by Rotamec. Since then it has struggled to start in the cold weather normally tripping out the thermal switch or blowing the 13Amp fuse. I'll add a link to a short video which illustrates the problem. The compressor isn't tight and can be rotated easily by hand.
I have spoken to Rotamec but they don't have any suggestions. As far as I remember cold weather didn't bother it before the motor gave trouble.
Any ideas please?
https://www.youtube.com/watch?v=uQpJ81ZWMB0
[Edited on 6/1/21 by John Bonnett]
theconrodkid
posted on 6/1/21 at 07:44 PM Reply With Quote
is the unloader working ?
who cares who wins
pass the pork pies
John Bonnett
posted on 6/1/21 at 08:01 PM Reply With Quote
I've never heard of that let alone know if it's working. I'm sorry I'm a complete dunce with most things electrical so can you explain please?
r1_pete
posted on 6/1/21 at 08:20 PM Reply With Quote
My old machine started doing the same in cold weather, I put it down to cold thick oil and the motor aging.
Fresh oil helped, but I ended up replacing it...
posted on 6/1/21 at 08:26 PM Reply With Quote
Unloaded valve could be sticking, normally fitted in the main pump to cylinder pipe and has a small pipe attached . Had similar problems years ago .
theconrodkid
posted on 6/1/21 at 08:35 PM Reply With Quote
as above, when it starts spinning, air is dumped through the valve till the motor gets up to speed then closes, you should be able to hear / feel it.
who cares who wins
pass the pork pies
posted on 6/1/21 at 09:02 PM Reply With Quote
The Mig Welding Forum has a section covering air compressors , you may find better advice there?
daviep
posted on 7/1/21 at 08:54 AM Reply With Quote
It's a small valve often located inside the start stop switch. You should hear a hiss of air when the motor stops when full pressure is reached? If you don't hear the hiss then unloader maybe faulty or blocked up with gunge. There will be a small air pipe going up into the switch, this connects to the unloader.
Regards
Davie
John Bonnett
posted on 7/1/21 at 09:08 AM Reply With Quote
Thank you all for your very helpful replies. I'll investigate.
SteveWalker
posted on 7/1/21 at 12:33 PM Reply With Quote
I don't know if they do it at all in small compressors, but instead of an unloader valve, large industrial compressors unload by mechanically holding the inlet valve(s) open for starting and stopping.
obfripper
posted on 7/1/21 at 01:21 PM Reply With Quote
The contactor in the stop/start switch can also arc when worn which can cause poor starting torque and tripping fuses, most industrial rated 1ph compressors use a 3ph contactor but only use 2 of 3 contactor terminals, so a temp fix is to swap the pair of wires from the worn contactor to the unused pair.
Dave
John Bonnett
posted on 7/1/21 at 04:33 PM Reply With Quote
Well I've checked that the unloader valve is working so I don't think that can be the problem.
God point about the contacts on the on/off switch. thank you for that.
