JAG
posted on 31/1/05 at 10:31 AM |
Wiper switch - get round?????
Is there one??
What have you done??
I am aware that there is a special switch available from SVC but it's £20 Not really in the spirit of Locost.
Is there a get-around that uses an ordinary switch or has everyone bitten the bullet and located one of these special switches (perhaps for less than
the SVC price?)
Justin
posted on 31/1/05 at 12:04 PM |
Single speed wipers?
Do you need two speeds? Unless you have to use the car you're going to avoid the rain if possible anyway.
JAG
posted on 31/1/05 at 12:26 PM |
I only need one speed but I understood that the 'special' bit is related to the park circuit.
When in the 'off' position the live feed is connected to the 'park' circuit.
Justin
locoboy
posted on 31/1/05 at 01:58 PM |
Jag,
Is auto park an SVA requirement?
I just have mine wired to the slow speed with an on / off rocker switch,
ok it means you can switch them off and they remain halfway across the windscreen but its no hardship to turn it off at the end of its sweep.
Locoboy
posted on 31/1/05 at 02:05 PM |
I believe it is...
DJ
chunkielad
posted on 31/1/05 at 02:31 PM |
The manual says....
Each wiper must have one or more sweep frequencies. In either case, one frequency must be at least 45 cycles/min (a cycle is the forward and return
movement of the wiper). The engine may be running during this test.
Reasons for failure.
Frequency not meeting 45 cycles/min on at least one setting. Not continuing to operate automatically when switched on. Not returning automatically to
a rest position which is at or beyond the outer edge of the swept area. Not being capable of being lifted from the windscreen.
There are additional notes for washer system.
monkey69
posted on 31/1/05 at 03:10 PM |
How about this for a work-around - don't put your windscreen on for SVA!
No windscreen means no wipers, demister and no washer required. Hence, they will not be tested.
timf
posted on 31/1/05 at 03:11 PM |
old mini in a scrap yard
mini wiper switch £1.50 or in the pocket if your dishonest
posted on 31/1/05 at 04:18 PM |
The self park is a limit in the gearbox usually, nothing to do with the switch. It locates in a notch on the gearwheel so it stays live till it
reaches the park spot. Look at the wiper section on the SVC website. http://www.s-v-c.co.uk/
There's an exploded diagram showing it in detail.
JAG
posted on 31/1/05 at 04:55 PM |
Peteff, from the SVC website;
It is important that you use a correct wiper 2-speed switch. The reason for this is that when the switch is in the off position with the ignition
switched on there is one connection which becomes live. This operates the parking position. If you use a non-live switch then the wipers would stop
whenever the switch was switched off.
Special switch mate
Justin
Spyderman
posted on 31/1/05 at 05:48 PM |
A special switch is not required!
There is a live feed to the wiper motor from the ignition circuit so that whenever the wiper switch is flicked (with ignition on) the wipers continue
to operate until the end of the sweep!
This is separate to the live feed via the switch. All the switch does is to activate the wiper motor passed the parked position. If switch is left on
it just ensures that wiper motor continues to operate.
As stated earlier the parking of the wipers is acheived by a cam on the motor working a microswitch which breaks the circuit when in a certain
position.
The switch has no way of knowing where the wipers are on their sweep so is nothing special!
Terry
Spyderman
posted on 31/1/05 at 11:34 PM |
My thoughts were
why does the feed to the park mechanism have to come from the switch? It is a switch.
JAG
posted on 1/2/05 at 09:35 AM |
Hhmmmm - my understanding is/was that when in the 'off' position the live feed should be connected to the park circuit.
When in the 'first speed' position the live feed should be disconnected from the 'park' circuit and then connected to the
'first speed' circuit.
When turned 'off' the live feed returns to the 'park' circuit and drives the motor until the internal cam mechanism cuts the
live feed.
Justin
JAG
posted on 7/2/05 at 10:55 AM |
Right, I got this working over the weekend so would like to correct my previously mis-informed self.
The park wire (from motor to switch) becomes live during the operation of park - thanks to the ignition live feed running to the motor (not switched)
and the gubbins inside the wiper motor.
When the wiper switch is in the 'off' position the park wire (brown with green tracer on my loom) must be connected to the wiper motor
feed.
The cam inside the motor casing will cut-off the live connection (down the park wire) when the motor reaches its parked wiper position.
My wipers now park
[Edited on 7/2/05 by JAG]
Justin
