Author: Subject: Fuse box upgrade + wiring connector uogrades
Stevestriker750
posted on 22/5/21 at 04:51 AM Reply With Quote
Hi all,
My Striker is having a lick of paint very soon so the rear tub is being removed. It has the traditional blue bullet type connectors for the lighting system and I thought it may be an idea to change them whilst it's being stripped down. Any suggestions on replacements.
I also have a very old style fuse box which I'm also looking at upgrading for reliability.
Any suggestions greatly received 🤗
roadrunner
posted on 22/5/21 at 09:38 AM Reply With Quote
https://www.ebay.co.uk/itm/Car-Waterproof-Electrical-Connector-Terminal-1-2-3-4-5-6-Pin-Way-Fuses-Kit-/353475221850?_trksid=p2349624.m46890.l49286
roadrunner
posted on 22/5/21 at 09:40 AM Reply With Quote
https://www.ebay.co.uk/itm/180PCS-2-4-WAY-PIN-6-3MM-ELECTRICAL-MULTI-PLUG-CONNECTOR-TERMINAL-BLOCK-CONNECT-/402838853723?_trksid=p2349624.m46890.l4928 6
roadrunner
posted on 22/5/21 at 09:41 AM Reply With Quote
I will be sorting mine out this winter.
big_wasa
posted on 22/5/21 at 10:00 AM Reply With Quote
I like the amp seal style connectors as above for most things over than high current stuff like the fan.
Fuse box, I’ve just bought one of these eBay Item
Nice quality. Modern switch gear pretty much needs a relay for everything.
The first thing I do with a kitcar is rewire it.
Stevestriker750
posted on 22/5/21 at 05:16 PM Reply With Quote
Thanks guys...
I'll be ordering and fettling next week hopefully
r1_pete
posted on 22/5/21 at 05:37 PM Reply With Quote
This was one of the best £35 I've spent on wiring tools.
Use uninsulated spades, bullets, multiplug pins etc....
https://www.vehiclewiringproducts.co.uk/p-269-ratchet-crimping-tool?search=Crimp%20tool
