New Topic New Reply
Author: Subject: Swapping single roll bar to MSA type - Indy Classic
cjwood23
posted on 24/5/21 at 09:06 PM Reply With Quote
I'm off to look at an Indy Classic at the weekend.
Spec is pretty close to what I want other than the roll bar.
It's a single non braced type.
Is it possible to swap these over without too much faff?
Ideally want a bar with rear bracing like the MSA style bars.
Looked on MK's website and they only seem to list full cages.
Have dropped them an email but thought I would ask on here too.
______________________
Chris
CosKev3
posted on 25/5/21 at 08:15 AM Reply With Quote
If the chassis has brackets on for rear stays it won't be too hard a job.
If it doesn't have brackets already it could be quite a big job,rear arches off,rear tub off,fuel tank out to weld brackets on.
Depending on how the bodywork has been fitted is the issue,if someone has used adhesive on the rear tub will take some getting off undamaged.
Same as arches,some people pop rivet them on,others bolt them on.
posted on 25/5/21 at 08:42 AM Reply With Quote
I built an MK Indy some years ago and opted for a welded on single roll bar without braces. Having opted for no braces MK didn't weld in the plates down either side of where the fuel tank sits to have rear braces. If building again I'd have rear braces.
As CosKev3 says removing the bodywork may be a fiddle depending on how it was fitted. I rivetted my rear tub on and bolted my rear arches. Others bond them on, which would be a faff to get them off without damaging the bodywork.
cjwood23
posted on 25/5/21 at 02:10 PM Reply With Quote
Thanks guys.
Will see if I can see anything on the chassis when I go and have a look.
Chris
SJ
posted on 25/5/21 at 02:12 PM Reply With Quote
Mine doesn't have them either so I'll be doing mine next winter
Mash
posted on 25/5/21 at 08:49 PM Reply With Quote
Did this on mine last year. Fortunately the builder did not use any adhesive to fix the body to the chassis, but it's still a time consuming job
I thought I could see light at the end of the tunnel, but it was just someone with a torch bringing me more stuff to do
strongrb
posted on 26/5/21 at 12:02 PM Reply With Quote
Your moniker
I do like your bottom line statement.
It fits my build/life situation to a tee. Lol
New Topic New Reply
