Author: Subject: Headlights dip & main
The Baron
posted on 24/4/24 at 06:16 PM Reply With Quote
I’m having an old man moment……
When going to main beam, should the dip beam go off, leaving sides still on?
Thanks in advance,
The Baron …
Ps I’m using sierra stalks (89 vintage)
[Edited on 24/4/24 by The Baron]
gremlin1234
posted on 24/4/24 at 06:40 PM Reply With Quote
it used to be that dip would always go off when main beam selected, - else the bulbs quickly overheat.
but if using 'flash' while dip are on both do light
many modern lighting systems keep dip on with main. (I think primarily because they can take a bit of time to light after being turned on)
sides should remain on if any lights are used. (drl is different again!)
The Baron
posted on 24/4/24 at 07:28 PM Reply With Quote
Thanks, I was starting to question my own sanity
B…..
adithorp
posted on 25/4/24 at 08:46 PM Reply With Quote
Using twin filament (H4) bulbs the dips need to go off when the main beam comes on, otherwise the bulb overheats and won't last long. For headlight flash it doesn't matter as both filaments won't be on for long enough.
http://jpsc.org.uk/forum/
