bigandy
posted on 13/2/05 at 08:30 PM |
Sierra front upright pinch bolt.
Evening all.
I was wondering if anyone knew what lenght and spec the pinch bolt used on the sierra fron uprights is? I think it is an M12 item, but I dont have
anything to check! I would get a ford replacement part, but It must be an off the shelf bolt that I can "acquire" from work tomorrow!
Dammit! Too many decisions....
posted on 14/2/05 at 12:36 AM |
Correct
bikkel
posted on 14/2/05 at 07:18 PM |
mine are 70 mm, as it also holds my mk cycle wing bracket
koen
www.zx12r-indy.tk
A fulton
posted on 14/2/05 at 07:29 PM |
pinch bolts
Sierra front upright pinch bolts are M12-60m![](/images//smilies/smile.gif)
bigandy
posted on 14/2/05 at 09:12 PM |
Brilliant cheers folks!
Out of interest, does this bolt have any particulare means of locking the bolt in place? I'm thinking some kind of threadlock compound, or
possibly a nyloc nut on the protruding thread.
ANdy
DarrenW
posted on 15/2/05 at 10:31 AM |
Mine is M12 8.8. Long enough to hold cycle wing bracket as well. I drilled clearance hole through upright (result of snapped bolts) and nyloc nut.
bigandy
posted on 15/2/05 at 01:45 PM |
That sounds like a good idea.... I had a nightmare getting the pinch bolt out when dismantling the donor parts. I ended up having to weld a new head
to the sheared off bolt, before I could remove it.
Now, Where did I put my 12mm drill!!!
Cheers folks!
