Author: Subject: fuel pipe length
wheelsinsteadofhooves
posted on 24/2/05 at 09:36 PM Reply With Quote
fuel pipe length
hi,
about to order fuel pipe for book standard locust (though may have zetec). how many meters fuel pipe will i need?
any experiance welcome. many thanks in advance.
antonyg
posted on 24/2/05 at 09:47 PM Reply With Quote
Got my fuel pipe from B&Q
10 mtrs of 8mm copper pipe in plumbing section for £11
posted on 24/2/05 at 09:49 PM Reply With Quote
not bad idea, but guess would stilln need some flexi bits for the corners/matings.
good tip though,
thanks
omega 24 v6
posted on 24/2/05 at 09:56 PM Reply With Quote
It'll bend no probs around a beer bottle diameter (theres always one handy) you can also solder it onto pipe fittings if you have the originals.
posted on 24/2/05 at 11:44 PM Reply With Quote
Ditto... Durite rubber lined P Clips to secure it from Auto Electricians.
NS Dev
posted on 25/2/05 at 08:29 AM Reply With Quote
Ditto, but from Screwfix
posted on 25/2/05 at 08:51 AM Reply With Quote
any issue with nylon p-clips? cheap as from maplins.
indykid
posted on 25/2/05 at 09:47 AM Reply With Quote
best not be. i've used loads of the buggers!
can't see any real reason for them to be frowned upon though
tom
nick baker
posted on 25/2/05 at 11:22 AM Reply With Quote
Polyamide plastics (Nylons)
..in the 3 most common forms (PA6, PA66, and PA11) are highly resistant to petrol and solvents.
Though I can tell you that they don't stand up to Hydrogen Peroxide.... not that it should cause any probs for you!!
Some meshes in preliminary fuel filters are Nylon...
Enjoy,
N
Edited when I realised I couldn't spell....
[Edited on 25/2/05 by nick baker]
nick baker
posted on 25/2/05 at 11:29 AM Reply With Quote
If you want a true lo-cost option though, Vauxhauls use a plastic (and rather flexy)
fuel pipe... Try stripping the lines from a couple of Novas... that should see you getting it to the right places without too many problems..
Danozeman
posted on 25/2/05 at 05:20 PM Reply With Quote
I wondered about using the vauxhall fuel pipe idea but will probably use copper so its allnice and shiney when i build it..
Dan
Mark Allanson
posted on 25/2/05 at 07:18 PM Reply With Quote
I tried the astra fuel line, and scrapped it in favour of galvanised 1x8mm steel. The plastic stuff tends to kink, and when it does, you cannot get it out, probably OK for straight runs, but be careful of even the slightest curve
