Author: Subject: clutch diode
minimanred
posted on 29/3/05 at 12:32 AM Reply With Quote
clutch diode
hello,
does anyone know what the function of the clutch diode is as fitted to the fireblade?
many thanks.
Ants
posted on 29/3/05 at 09:52 AM Reply With Quote
It's supposed to be one of the safety lockouts.
The other two are "Footpeg" and "Neutral"
Either disconnect it or leave it in... does little to affect anything. You'll have it in neutral to start anyway wont you?
If you want to remove it do this:
Locate the clutch diode. This is distinguishable by the following wired leading into the connector:
Two Light Green Wires connected.
Light Green/Red trace.
Green/Red trace
The connector itself is dead ended with a small black block on the end.
Chop this connector out - and proceed as follows:
Join the two Light Green Wires to the Light Green/Red trace.
Connect the Green/Red trace to earth.
DONE
[Edited on 29-3-05 by Hellfire]
ReMan
posted on 29/3/05 at 10:21 AM Reply With Quote
Originally posted by minimanred
hello,
many thanks.
Ants
So what is its function?
I think its so that the neutral light does not light when you pull the clutch in as standard, though I may be wrong, if it is its unnessesarilly complicates the wiring when the logic could have been kept in the ecu?
minimanred
posted on 29/3/05 at 09:01 PM Reply With Quote
looking at the wiring diagrams the later blades have the diode in the CDI.
so far ive "tricked" the stand switch and clutch switch into working and i just wanted to know if the diode could be left in the loom and not cause any problems
posted on 29/3/05 at 09:36 PM Reply With Quote
Yes it can be left in and no it doesn't cause any problems.
minimanred
posted on 29/3/05 at 09:50 PM Reply With Quote
what do you do with the black and yellow wire from the side stand switch that connects to a warning light?
ReMan
posted on 29/3/05 at 10:52 PM Reply With Quote
Pull it out or use it for anything else that you can switch to ground and light the yellow" S" light.
posted on 30/3/05 at 08:35 PM Reply With Quote
Originally posted by Hellfire
After inserting alower wattage bulb, we used it for the sidelight's...
ReMan
posted on 30/3/05 at 11:12 PM Reply With Quote
Perhaps a G force sensor, that made it light when you shoud be "S"ideways
