Newmot
| posted on 1/4/05 at 11:19 PM |
Reversing Lights
Can anybody confirm that the reversing light switch on the type 9 gearbox switches live not earth
Bart69
| posted on 1/4/05 at 11:38 PM |
It will switch either depending on the way you wire it. Its just an on/off switch
Pretty sure its the live though, earthed at the light cluster
Graham
[Edited on 1/4/05 by Bart69]
Newmot
| posted on 2/4/05 at 09:24 AM |
OK thanks.
Humbug
| posted on 2/4/05 at 10:38 AM |
Vaguely on this topic - do you have to use a Sierra plug on the pins, or do bullet connectors fit?
[Edited on 02.04.2005 by Humbug]
marshall
| posted on 2/4/05 at 11:16 AM |
i saved the plug that gose on it with a long bit of wire to go in to the engine bay hope it helps
indykid
| posted on 3/4/05 at 02:01 PM |
if you switch live, it saves an earth wire through the transmission tunnel, but as has been said, it's just an on/off switch so doesnt make any
difference.
tom
