white130d
posted on 16/4/05 at 07:23 PM |
Tail light mold
Been trying to come up with a cheap "classic" look for the tail lights so I made this plug. I am going to make a mold and then make them
out of fiberglass and as you can see fit the Land Rover Series tail lights.
Whatcha think...
"There's only 2 things that money can't buy, and that's true love and home grown tomatos" Guy Clark
white130d
posted on 16/4/05 at 07:24 PM |
and then
once molded, I will trim the sides to fit the curve of the rear wing/fender
posted on 16/4/05 at 07:36 PM |
If it was just flat at the back and stuck out a bit further it would take the Mk1 Mini rear light or two circular lights. Make one to fit the MGB rear
lights while you're at it David.
longwayoff
posted on 16/4/05 at 07:39 PM |
Yes I like them. I wouldn’t mind a set myself
white130d
posted on 16/4/05 at 07:42 PM |
You're right
I just looked at a Minisport catalog, the MK 1 Mini is a good looking lamp, but it's like 39 GBPs!!! I have an old B out in the south 40.
I'll take a look at them too...
David.
andyps
posted on 16/4/05 at 09:11 PM |
The mini estate/pick up lights would be better as they fit on a flat panel, unlike the mark 1 which has compound curves. Trouble is they are a bit
like hens teeth these days.
The mould looks good though.
niceperson709
posted on 16/4/05 at 10:54 PM |
I have a set of the afore mentioned Mini Van / estate tail lights that I intend to use and I like the base you have made I have plans to do some sort
thing my only crit is the stepped shape . another option I considered was the Morris minor tail lights or the early VW beetle lights . the red only
very early lucas tail lights would look the business but would require seperate indicators . Choices Choices Choices
Iain
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
white130d
posted on 16/4/05 at 11:51 PM |
Reason
The reason for the step was to accomodate the backside of the lamp assembly, they stick about 1.5" in and I was trying to avoid having them
protrude into the wheel area....
Once painted black or body color the step might (fingers crossed) be less noticable.
David.
niceperson709
posted on 17/4/05 at 12:01 AM |
Hi David,
I apreciate what you are saying and understand your reasoning . My coment was based purely on the Looks of your mount . peronally I think if it was
the same level as the bottom it would look more elegant ( and I could buy your'd rather than make my own ) any way it is good to see some
one getting away from the square across the width of the gaurd Caterham aproach . Good luck with it .
Best wishes
Iain
Best wishes IAIN
posted on 17/4/05 at 06:26 AM |
I like the idea they are not unlike the chrome plinths that were fitted to the rear of the 50s MG TF,however I also agree it would look better with
both lights mounted on the same plain.
white130d
posted on 17/4/05 at 01:08 PM |
This is what I want
but being a cheap bastard ($40 here in the states for the lamp only) This is the lamp used on Frogeyes, TR2/3, 1500 MGA and I am sure a whole host of
others. The plinth (black part) is probably custom to the 7 wing and I would have to make it too....
posted on 17/4/05 at 05:42 PM |
Both parts are Morris Minor items.
