Author: Subject: wiring question again
saigonij
posted on 17/4/05 at 09:14 AM Reply With Quote
All,
I have figured out a bit more of our wiring but i need help again.
At the ignition switch end of the Luego loom, i have the following.
1 large core brown cable, about 5mm in dia
2 med core brown wires about 2mm in dia
These are both Perm Lives.
2 White med core wires about 2mm dia
This is Ingition supply to the loom.
So, i can solder the 2 white wires to the black/yellow on the ignition barrel, thats fine.
My problem is the perm lives. Im going to solder these to the large RED wire from the ignition barrel ( the other end of the large brown 5mm is connected to the starter - which in tern is connected to the battery + ).
I will have to solder this large brown wire, to the two smaler brown wires, and then to the red wire from the ignition switch -> how the hell am i gonna do this??? Its fairly heavy duty wire!
Any suggestions on howi should safely and securely connect all these 4 wires together?
Thanks,
omega 24 v6
posted on 17/4/05 at 11:31 AM Reply With Quote
solder them all together and then cover them with heat shrink sleeving. Use the type with built in resin/glue type sealant which seals all joints from moisture and is thicker as well to insulate better.
saigonij
posted on 17/4/05 at 03:23 PM Reply With Quote
it was taking my poor soldering iron a while to heat up, any suggestions on what wattage to go for , for this heavy duty stuff?
posted on 17/4/05 at 03:36 PM Reply With Quote
I think it's more down to tip size than wattage when you're doing thicker stuff. We've been using a 40w iron with a broad chisel tip and it works well. Load it up with solder and when the wire is hot you'll see it run in. Splice the wires together and don't forget to put the shrink wrap round the thickest first, as if you would.
