Author: Subject: Savage Fog Switch
BMF
posted on 17/4/05 at 10:30 PM Reply With Quote
Savage Fog Switch
Anyone wired up one of the Savage fog light switches?
It has
N/C x 2
N/O x 2
Common x 2
Led +
Led -
To start I connected by input and output to one set of the N/C and N/O and an earth to one of the common connections . As soon as I turn lights on it then blows the fuse every time!!!
If I touch the fog in and out wires the light illuminates so not prob with that, just can't work out what is wrong!
Cheers Ben
stevebubs
posted on 17/4/05 at 10:41 PM Reply With Quote
If it's the standalone switch with 6 switch (made up of 2 x 3pin switches) pushed on the back, then I've several in my car.
Basically, the centre one is a common feed, 2 either side of it are push to break or push to make.
So put one of the 2 wires you connected to make the lamp light up to the centre connection, and the other to the push to make connection.
This is probably clear as mud....
[Edited on 17/4/05 by stevebubs]
shortie
posted on 18/4/05 at 05:09 AM Reply With Quote
I used savage switches on mine, diagram including them here...
http://www.shortshouse.plus.com/WiringDiagramv10.pdf
HTH,
Rich.
colibriman
posted on 18/4/05 at 07:20 AM Reply With Quote
your earth should go to led -
input to common nearest n/o
output to n/o
that should do it...
HTH
Colin
need a bike engine? - www.colibriman.com
SVA ready Mk Indyblade possibly for sale.....if the offers good...!
