antonyg
posted on 23/4/05 at 05:13 PM |
ignition module/amplifier
Hi, i'm sure this will have been disscussed before but i am unsure which wires go where in the ignition amp i have 3 different diagrams ( haynes
manual, tiger book ) and this one:
Pin/Function
1 To Coil -ve Pin 1 & Rev Counter supply
2 To Coil +ve Pin 15 on Ignition Switch
3 To Ignition switch 50
4 To Pin 1 on Induction Distributor
5 To Pin 15 on Induction Distributor
6 To -ve Earth
Sierra Colour
1 Gn
2 Bk
3 Bk/Gn
4 Gn/Y
5 Bk/R
6 Bn
engine turns over whichever one i use but is one better than the other or doesn't it really matter?
Thanks for the help Antony
forgot to mention amp is off sierra 2.0ltr
[Edited on 23/4/05 by antonyg]
posted on 23/4/05 at 05:38 PM |
No3 goes to the cranking feed on the solenoid on mine but it's the same difference, the rest of it's same
Avoneer
posted on 23/4/05 at 09:48 PM |
Hi Ant,
Depends what number you have on your little black box.
If you post it on here, I can double check how it should be wired.
Should be the same as mine and Carls though.
Pat...
antonyg
posted on 24/4/05 at 02:46 PM |
sorted it now
wired it up as above filled with petrol and it started straight away
