Author: Subject: Full Beam and Head Lights
saigonij
posted on 23/4/05 at 09:53 PM Reply With Quote
Been wiring up the Head lights today and i have a question.
On most ford cars, with the head lights on, when you flash the full beam, the head lights stay on, when you turn on the full beam ( pushing the stick towards the dash ) the head lights will turn off.
Is this an SVA requirement? Using the Luego Relay pack, i cant think of an easy way of doing this.
Donners90
posted on 24/4/05 at 07:54 AM Reply With Quote
Discussed here
http://www.locostbuilders.co.uk/viewthread.php?tid=16338
I'm going by what the last post says . Can't see any easy way of getting them to flash using the Luego loom either
HTH
James
[Edited on 24-4-2005 by Donners90]
posted on 24/4/05 at 08:14 AM Reply With Quote
ISTR i used a couple of relays to sort this one.
ReMan
posted on 24/4/05 at 09:25 AM Reply With Quote
Originally posted by saigonij
B
If the Lueog relay pack has a relay for high beam and another for dip beam, you should only need to put a link in on the switches so that it fires the high beam relay from a live feed on pin 31 to 56a which is main beam, make sure main and dip arnt reversed else it wont work
RazMan
posted on 27/4/05 at 06:40 PM Reply With Quote
This is often the case in twin headlight setups and works well. Of course, if you have only a single headlight and therefore single (twin filament) bulb you will quickly burn out the bulb.
Raz
