Mave
| posted on 28/4/05 at 06:24 PM |
how to make LED warning lights?
What do I have to fit between a LED and my wiring loom to have it work as a warning light? Only a resistor? And if so; what kind?!?
I like the Bright6 unit, but due to the shape of the rear, I can't fit it at the position where I want it, so I'm looking for an
alternative.....
Marcel
flak monkey
| posted on 28/4/05 at 06:32 PM |
Here is the wiring diagram for the bright6 module, it will give you an idea of what you need. No values on resistors though.
From left to right (if you cant read it) Indicator (L), main beam, ignition, oil, brake fluid, incicator (R).
Sera
http://www.motosera.com
JonBowden
| posted on 28/4/05 at 07:02 PM |
It's many years since I did any electronics - but here goes.
R = V / I (resistance = voltage drop / current)
A notmal LED uses agout 20mA (0.02A)
The voltage drop accros the LED is fixed at about 1.2V
Battery voltage when engine running = 14V
Thus voltage drop required accross resisitor = 14 - 1.2 = 12.8V
using R = V / I above, R = 12.8 / 0.02 = 640 ohms.
Your LED may need a higher current (say 50 to 100 mA) thus requiring a lower value resistor.
Jon
paulf
| posted on 28/4/05 at 07:14 PM |
I used the standard Maplins 10mm leds for my indicator warning lights, I joined the negative leads together and used a 470 ohm resistor, the other end
connects directly to the 12v signal.
Paul.
clbarclay
| posted on 28/4/05 at 09:12 PM |
Different LEDs have different specifications. Find out what spec of the LEDs your going to use. Also experiance says that an LED similare spec to the
example jon gives can work quite well with resistors ranging from 470 to 1000 ohms.
tks
| posted on 29/4/05 at 07:21 AM |
mhhhh
you can better search for an sheme that gives you always the same brightness.
It will add an component but its better quiality..
Soow if i was u also hookup an 7805 regulator
and start from there supplying the voltage to the leds...
if your battery voltage then drops to 12 volts instead 13 or 14
then nothing happens on the leds
regards,
TKS
JonBowden
| posted on 29/4/05 at 10:22 AM |
I dont really think it's worth it just to deal with the difference between 12V and 14V.
However, if you do, then you will be running the LED / resister combination off 5V, thus the voltage drop accross the resistor will be 5 - 1.2 = 3.8V.
Use this in the earlier equation combined with the current required for the LED to calculate the resistor value.
Jon
craig1410
| posted on 29/4/05 at 11:57 AM |
Be aware that some of the extra bright LED's achieve the extra brightness by having two or more LED's in series. This means that the
voltage drop across the LED will be higher so make sure you get the spec for your LED's and run the numbers through the above formula.
If you want to achieve a stable brightness then you can use a different type of diode called a Zener diode along with another resistor to limit the
incoming voltage to something below 12V regardless of battery voltage. To do this you need to place the additional resistor between the incoming
signal and the existing resistor and then place the zener diode in reverse bias between the junction between the two resistors and earth.
A Zener diode in reverse bias (ie. Cathode to positive, anode to earth) will not conduct any electricity until the voltage across it exceeds the
defined threshold. The threshold voltage can be chosen when choosing the device. Once the threshold is exceeded, the zener will conduct quite easily
until the voltage falls back below the threshold when it will "switch off" again. You must have a resistor between the cathode of the
zener and the incoming signal to ensure that the zener doesn't conduct too much current as it tries to reduce the incoming 12V to, say, 5V. The
additional resistor will do this job quite happily instead.
So, what you will now see at the original circuit is a voltage of either 0V or the value of the zener diode, regardless of battery voltage and this
will ensure that the brightness of the LED's remains constant.
This circuit could be altered to allow brightness adjustment with the addition of a potentiometer. I can give some details if this is of interest.
Craig.
Craig.
Mave
| posted on 29/4/05 at 03:06 PM |
Ok, so all in all it's not that complicated! Thanks, I'll give it a go.
Marcel
RazMan
| posted on 29/4/05 at 10:49 PM |
It is worth remembering that you can give the LED's a dual brightness by altering the resistor value according to the situation - useful for
visibility with less dazzle during night / day modes.
Raz
