Author: Subject: misterieus blue plug
dr-fastlane
posted on 20/6/05 at 05:16 PM Reply With Quote
Today I was busy to fit the wiring loom into my car. And I found an misterieus blue plug.
The wiring loom is from an 1987/1988 Ford Sierra 2.0 injected sohc.
Where must it plugd into??? Does someone know.
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
dr-fastlane
posted on 20/6/05 at 05:18 PM Reply With Quote
Originally posted by CairB
dr_fastlane,
If you can post which pins on the EECIV ECU connector that the wires connect to then the Haynes manual should yield the answer.
If you haven't got the manual then I'll have a look when I know the pin numbers.
Colin
The brown/yellow wire connects with pin 57 on the EECIV ECU. The brown wire is an common earth link. I have the Haynes Ford Sierra 4 cyl. Service and Repair Manual but there is no connection pin 57 in the wiring diagrams.
Should this blue plug have to do with an ABS system?
Roy.
[Edited on 20/6/05 by dr-fastlane]
dr-fastlane
posted on 20/6/05 at 05:23 PM Reply With Quote
Now this topic is in the right part of this forum.
Roy:
tks
posted on 20/6/05 at 05:40 PM Reply With Quote
eec??
does the engine run??
speedo limit??
rpm limit??
Tks
dr-fastlane
posted on 20/6/05 at 05:45 PM Reply With Quote
EEC IV modul says the haynes manuale.
And yes, the engine, speedo and rpm limit are running.
Roy.
CairB
posted on 20/6/05 at 08:04 PM Reply With Quote
Pin 57 on the EECIV connector looks like the main 12V common feed for injectors on the diagram in my Haynes manual.
The closest candidates for your connector look like the flyback diode for the idle valve or the brake fluid level, but neither seem likely, sorry.
Colin
