givemethebighammer
| posted on 10/7/05 at 06:53 PM |
Anyone know where I can get one of these ?
scrapyard prefered otherwise electronics supplier ?
I think they call them 3 pole junior timer housing ?.
I need to join a TPS sensor to my ecu (this would normally plug straight on to the weber TPS). However I am experimenting with some bike carbs and
want to connect the honda TPS to my ECU without butchering the loom.
thanks
stevebubs
| posted on 10/7/05 at 07:07 PM |
Vehicle Wiring Products
RS Components
givemethebighammer
| posted on 10/7/05 at 07:10 PM |
Thanks neither seems to stock a 3 pole male housing of thie type. 2 pole yes but 3 no ?
omega 24 v6
| posted on 10/7/05 at 07:28 PM |
They look very similar to many of the fuel inj plugs or cam sensor plugs on my v/hall. However i'm not sure if they are 3 pin or not.
If you have a look in a commercial vehicle scrap yard for a leyland daf 7.5 tonner ( i think its a model 45 or a 55 ) then there are plugs with 3
pins similar to these.
Sorry if this is a bit vague i'll try and have a look for one on a new daf tomorrow if i've time.
madman280
| posted on 10/7/05 at 07:37 PM |
Looks to be a bosch style connector. Maybe a wander around a scrap yard might yield a european vehicle with the right connector
stevebubs
| posted on 10/7/05 at 08:23 PM |
thanks
U2U Colibriman and see if he has a spare bit of loom lying around.
Alternatively, contact a bike breakers
....or scout around a biker gathering with set of wire cutters :O
Mix
| posted on 11/7/05 at 06:18 AM |
Try Martin Fox at MEF Motorsport, he is supplying me with the plugs and sockets for my injection.
<martinfoxg3zuz@ukonline.co.uk>
Mick
davidwag
| posted on 11/7/05 at 07:40 PM |
Hi
The photo is of crank position sensor wiring on a vauxhall vectra type ecotec engine. You could try that.
givemethebighammer
| posted on 11/7/05 at 08:08 PM |
thanks,
I'm off to scrapyard tomorrow lunchtime to see what I can find. I also found a sierra master cylinder low fluid warning cap in the garage this
evening. The plug is the same as the TPS one so I may be able to make a 3 pin male socket from the cap socket.
.........off to scrapyard with pair of wire cutters
thanks
givemethebighammer
| posted on 12/7/05 at 01:02 PM |
Got one Davewag was in the right area
Vauxhall Calibra 8v K reg - cable that is attached to the cam belt cover.
thanks
NS Dev
| posted on 12/7/05 at 01:38 PM |
was going to say (too late now!!) that Davewag is dead right, Vauxhall crank position sensor lead has those connectors (and is what is in the pic on
an XE I believe)
davidwag
| posted on 12/7/05 at 09:47 PM |
Glad to know I could be of some help!!!
