Avoneer
posted on 14/7/05 at 09:20 PM |
Toggle switches - how many etc.
Hi
As I intend not to use any stalks due to my paddle shift mechanism, I intend to mount a "bank" of toggle switches with rubber covers on
top of the tranny tunnel just in front of the dash.
Just trying to make sure I don't forget any.
My tell tails will be the one's already present in the Fireblade clocks and that "Bright 6" little number.
So using simple toggle switches:
1) Indicators - ON/OFF/ON
2) Fog light - ON/OFF
3) Lights - OFF/ON/ON
4) Full beam - OFF/ON
5) Hazards - OFF/ON
6) Horn - OFF/ON
7) Fan over-ride - OFF/ON
Does that sound like everything I'll need?
Pat...
posted on 14/7/05 at 09:23 PM |
Wipers? No?
shortie
posted on 14/7/05 at 09:29 PM |
Avoneer,
1) Indicator on/off/on
2) Sidelights on/off (permenant feed)
3) Headlights on/off
4) Main Beam on/off
5) Hazards on/off
6) Fog on/off
7) Start Button momentary on
8) Fan Overide on/off
HTH,
Rich.
Avoneer
posted on 14/7/05 at 10:37 PM |
Hi Rich,
Cheers.
Why is there a permanent live to the sidelights - ahh - so the lights some on without using your key - shouldn't this be the headlights as well
- and the horn?
Bits that will throw/worry/stress me are the full beam/headlight switching thing and the hazard circuit - but I'll worry about them later.
Pat...
Kissy
posted on 15/7/05 at 05:55 AM |
...fuel pump??
shortie
posted on 15/7/05 at 06:01 AM |
Sidelights have to be operational with the ignition off, as do the hazards and horn.
Switching for hazards and main beam etc is not too bad, have a look at my wiring diagram which should help.
http://www.dewweb.co.uk/indyblade/images/Indyblade_wiring_v17.pdf
Rich.
[Edited on 15/7/05 by shortie]
silex
posted on 15/7/05 at 07:02 AM |
A quick question to you guys with the SVA manual.
I don't have the SVA manual itself, but direct access to the full EU regulations - In the regulations it states that switches of this kind
(lights, etc) should carry a depictive symbol - not even the written word.
Is this the same in the SVA manual, or do you intentend to add symbol stickers or similar close to the switches.
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
Avoneer
posted on 15/7/05 at 11:09 AM |
I'll be putting stickers next to the switches and the tell-tales will all be correctly symbolled.
Fuel pump - that's another one.
Any more???
Pat...
chrisf
posted on 15/7/05 at 12:52 PM |
Fuel Pump
Why not wire the fuel pump to the ignition circuit? So when the ignition is on, so is the fuel pump. Is there a down side to this?
EDIT: As for the fasher/hazard wiring, I used one of these. Some might snub their
nose at the time-based flashing devices but it was the easiest solution I could come up with. Like you, I'm not using stalks.
--Chris
[Edited on 15/7/05 by chrisf]
Avoneer
posted on 15/7/05 at 03:28 PM |
I'd rather have control over the fuel pump so I can have all the electrics on, without the pump whirring away at the back all the time!
Pat...
Danozeman
posted on 15/7/05 at 05:00 PM |
Surely it would be easier and better to have the fuel pump ign controlled so u dont run it dry by forgetting to turn it on?
It shouldnt pump once the pressures up anyway.
Dan
Avoneer
posted on 17/7/05 at 09:17 PM |
Shortie - did you do that wiring diagram?
If so, does it all work fine and would I be right in saying that you are using 6 relays and 6 fuses all together?
Pat...
