New Topic New Reply
Author: Subject: mk suspenion setup
mkblade
posted on 25/7/05 at 08:41 PM Reply With Quote
mk suspenion setup
took bec mk out for the first time at the weekend good fun although its very bumpy to say the least .im using gas springs and shocks, i want a softer ride do i slacked off the springs a few more turns ?
and i have set up the shocks half way i think it was 20 clicks .
its the de-deion beam set up at the back.
has anyone eles got any advise on set up .
thanks
simon
zetec
posted on 26/7/05 at 06:47 AM Reply With Quote
Your shocks are way too hard. Start of with 2-3 clicks off softest and go up from there, I use 5-6 and thats with a car engine. Also tyres should be 18-20psi as a starting point.
Good luck, might save you bouncing all over the road!
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
bikkel
posted on 26/7/05 at 07:05 AM Reply With Quote
hi
just adding a question to the topic:
does anybody know the preferred position of the excentric mushroom inserts for best handling (not sva selfcentering?)
koen
netherlands
www.zx12r-indy.tk
www.zx12r-indy.tk
New Topic New Reply
