Author: Subject: wiring loom.
Danozeman
posted on 7/8/05 at 06:55 PM Reply With Quote
wiring loom.
Im looking at using a premier loom.
My car will be running sierra switches, electric fuel pump and a zetec with the ecs ecu for the ign for the time being. Does anyone know if the sierra loom they do will run this? Or is it a special made jobby?
Dan
posted on 7/8/05 at 07:02 PM Reply With Quote
Premier loom will be OK for Sierra switchs, send them the connector blocks with a few inchs of cable and tell them the part number of the switchs, fuel pump wire is in place IIRC but no relay for pump ? shouldn't be a problem . As for ECU I'm not able to help but Premier should be able to.
Danozeman
posted on 7/8/05 at 08:14 PM Reply With Quote
I think the ecu should just need the feed. the rest i can do. i cant be totally lazy.
Dan
mad-butcher
posted on 10/8/05 at 06:48 PM Reply With Quote
it should be noted alan makes a small charge for fitting the plugs about £10 but beleive me it's money well spent
tony
