Author: Subject: Lazy question on the Bright6
posted on 11/8/05 at 10:44 AM Reply With Quote
Has anyone worked out the value of resistor needed to reduce the high-beam warning light to a level that doesn't make the eyes water at night?
I could undo my dash and faff around for a few hours, trying to find the correct value... but if someone else has already made the effort...
BTW: I don't care about the indicators - I keep leaving them on anyway, so the brighter the better! Same for the warning lights - they only come on in case of emergency, so brightness is good.
James
posted on 11/8/05 at 11:12 AM Reply With Quote
No idea about the resistor value but what I have noticed is that if you wire it up 'right' you can make smoke come out of it and then have half the LEDs stop working!
Must be based on an early development model by 'Q' for James Bond.
James
P.S.
David,
What about fitting the variable resistor from a Sierra?
[Edited on 11/8/05 by James]
ned
posted on 11/8/05 at 11:41 AM Reply With Quote
Originally posted by James
P.S.
David,
you mean like a dash lights dimmer switch
beware, I've got yellow skin
posted on 11/8/05 at 11:53 AM Reply With Quote
I guess that a variable resistor is the easiest way to fix the problem! I could just tuck it out of sight behind the dash. Reliability would be the only issue - vibration and damp air aren't good for variable pots.
The alternative would be some clever electronics (i.e. a transistor and a few resistors fed from the lighting circuit) but life's too short.
posted on 11/8/05 at 09:37 PM Reply With Quote
im not sure, but i didnt think you could use LEDs with resistors? someone correct me...
Benzine
posted on 11/8/05 at 09:58 PM Reply With Quote
What about some kind of plastic filter/sunglasses material type thing for a light reducing effect
posted on 11/8/05 at 10:02 PM Reply With Quote
the dash lights would be fine, but everything else would be a dark blur
Benzine
posted on 11/8/05 at 10:08 PM Reply With Quote
James
posted on 12/8/05 at 07:30 AM Reply With Quote
David,
You can buy a dimming kit for it for £1.99 from the manufacturers.
Probably less effort than fabircating something!
James
posted on 12/8/05 at 07:35 AM Reply With Quote
It's just that I have a box full of assorted resistors at home...
...if I have the right value then all it will cost me is some spare time.
DJ
VinceGledhill
posted on 12/8/05 at 09:11 AM Reply With Quote
Try a few in series. Can't hurt owt
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
posted on 24/10/05 at 01:08 PM Reply With Quote
LATE UPDATE!
I had a e-mail from Lightning Looms a short time ago...
"The value of resistor you can use is between 6k2 and 7k5 around 0.5W rating but this won't be visible in bright sunlight, but you can wire a switch in parallel to the new resistor then you can adjust this for daytime and nightime driving."
I fitted a 6k2 and it's still bright (but at least now I can see down the road when I'm on full-beam!). If I get round to taking the dash off again then I'll probably fit the 7k5. I can only just see the light in bright sunlight but, to be honest, I don't care when it's sunny - when the sky's a bit more gloomy then the light's clearly visible.
macspeedy
posted on 24/10/05 at 03:43 PM Reply With Quote
i was going to use the less technical solution of putting some paper down the hole
tks
posted on 24/10/05 at 05:45 PM Reply With Quote
mhhh
wy not use an auto dimmer?
use an var resitor called LDR...
then you should be able to fabricate...
an.. auto dimmer is light full brightness
is it dark minimum..
Tks
posted on 24/10/05 at 07:11 PM Reply With Quote
I thought about getting clever with electronics - then realised that it wasn't in the spirit of the car - as simple as possible.
The resistor cost me 0.7p in Maplins (I was too embarrased to buy just 1 resistor, so bought some other stuff as well!). I can see the lamp when I need to, and don't care when I can't see it (bright daylight) 'cos I won't have my headlights on then anyway.
907
posted on 24/10/05 at 11:24 PM Reply With Quote
I assume you'll be attending the Tuesday night meetings David,
not the Sunday morning one's.
Paul G
