shortie
| posted on 31/8/05 at 06:11 PM |
6.3mm blade connectors
Just wondered if anyone could tell me what the max amps for a 6.3mm blade connector is?
ta,
Rich.
| posted on 31/8/05 at 06:14 PM |
16A IIRC
theconrodkid
| posted on 31/8/05 at 06:17 PM |
red is 8.75/blue 17.5/yellow 32 amp
who cares who wins
pass the pork pies
| posted on 31/8/05 at 06:27 PM |
I only use the uninsulated ones (FB6) as they are much cheaper. The one's which you buy the little clear boots for - what A are those? Take upto
5.5mm^2 wire
I found these to be the best.... dont get em from Maplins metal is too brittle - tabs snap off!
wilkingj
| posted on 31/8/05 at 07:02 PM |
I get all mine from Blue Beehive, never had any problems. Good and Quick service and good quality bits.
Best Regards
Geoff
http://www.v8viento.co.uk
Nitrogeno25
| posted on 31/8/05 at 11:00 PM |
5.5mm^2 wire
BTW, where I can I get a really crimping tool for that onw?? because I get 2 and destroy like 10 connectors!
Thank you
theconrodkid
| posted on 1/9/05 at 06:26 AM |
5.5 should be blue size,17.5 amp,agree about them breaking,thats why i use the insulated ones from blue beehive and a decent crimping tool
who cares who wins
pass the pork pies
jos
| posted on 1/9/05 at 07:52 AM |
http://www.bennetts.com/tools/handtools?contentId=41980
Bennetts do a ratchet crimping plier. The one you want is the green handled pair but I have no idea how to make sure you get the green handled pair
as all three pairs seem to have the same order code.
Nitrogeno25
| posted on 1/9/05 at 01:45 PM |
Thank you, I tried one of these but I can't get good results, maybe I'm not using it correctly but I have some connectors proffesionally
done and it's a big difference.
Thank you very much.
davidwag
| posted on 4/9/05 at 06:31 PM |
hi,
I bought a pair of the blue handled ratchet crimping pliers from Premier wiring.
A bit dear @ £30 but first class crimps.
I'm now on my third complete wiring loom. plus all the day to day stuff i do.
Won't do flag terminals but does do the pins for Emerald ECU multi-plug / mini timer multi-plug etc.
| posted on 4/9/05 at 11:19 PM |
For the non-insulated terminals you need these
on this page
HERE marked as PR4 and are £26.38.
Sorted
davidwag
| posted on 5/9/05 at 07:08 PM |
These are the pliers that I use
davidwag
| posted on 5/9/05 at 07:09 PM |
And this is a terminal i crimped with them.
Nitrogeno25
| posted on 5/9/05 at 07:23 PM |
That looks very good.
Thank you davidwag,
Thank you Hellfire.
