Author: Subject: Fog light switch
tri
posted on 4/9/05 at 12:26 PM Reply With Quote
Fog light switch
can anyone help looking how to wire up the rear fog light switch.its a Delta switch from Premier Wiring.
There are 4 wired on the loom
A- Red (posative)
B-black (earth)
c- blue yellow (wired to rear fog light)
D- blue red (?)
The switch has four conector
1
2
3
5
what wired go where
any help would be much appreciated
Tri
jonbeedle
posted on 4/9/05 at 12:52 PM Reply With Quote
Mine had three wires. One for the light in the switch and one to the fog light and an earth. I'm guessing but I would think that the red is a live, and the red/blue is for the light on the switch (have you got a light on the switch?) If so you should find out which terminals are connected together using a continuity tester and connect the fog light wire and the red/blue to these then find out which is the live terminal by putting one side of your tester on one of the free terminals and the other on one of the terminals you have just connected the fog light and the red/blue terminals to, then operating the switch, you should get continuity on one of these when the switch is operated and you should connect your red wire to this, the other terminal should be the earth (black).
Your fog light should only come on when your lights are on so I would imagine your red wire comes from the main light switch.
This is all guess work as I can't see your loom, so I could be totally wrong
If in doubt give Alan at Premier Wiring a ring (01483 236976) he's very helpful especially if you bought your loom from him.
Hope that helps.
Jon
[Edited on 4/9/05 by jonbeedle]
"Everyone is entitled to an opinion however stupid!"
