stuartsavill
posted on 11/9/05 at 01:56 PM |
Sierra Steering Column Switch Gear
I wonder if anyone can help me.. I am putting together a Luego Viento, and using a sierra steering column. My problem is this:
The pin numbers that my wiring loom says does not match (all) of the numbers on the switch gear on the steering column.
I am told that there are two versions of the switch gear, one with a square hazard switch, and one with a circular one.
I have the switch gear with circular, and the loom (I believe) is made for the "square hazard" switch gear.
Does anyone out there have a pin mappings / conversion sheet to show which pins on the new switch gear I could use?
Many thanks in advance,
Stuart.
Deckman001
posted on 11/9/05 at 03:05 PM |
Can't remember the actual pin numbers, but your only problem is sorting out which type of switching you have , ie: 83bg or 87 bg, one is
switched earth, the other isn't !! will have a look at the disructions i have , by the way, what loom are you using? as with this info, it
can make it easier for people to give you advice
Jason
Deckman001
posted on 11/9/05 at 03:10 PM |
As from Premier loom
83BG (switched live) h/lamp flash(15) Main Beam(56a) dip beam(56b) supply from light switch (56)
87BG (switched earth) Brown h/lamp flash other wires as above
Hope this helps
Jason
Paul (Notts)
posted on 11/9/05 at 03:11 PM |
according to my premier wiring loom info -
BG83 - switched live
BG 87 & 90 - switched earth
I'll have a look for the pin numbers but cant post them for a day or two . If you dont get an answer then U2U me and Ill get back before the end
of the week with the info.
Paul
too slow with the post ..................
[Edited on 11/9/05 by Paul (Notts)]
stuartsavill
posted on 11/9/05 at 04:56 PM |
hey, thanks for the fast response...
the loom I am using is from a Dax Rush (altho the car I am building is a Luego Viento)
anything that can help would be great
Thanks,
Stuart.
stuartsavill
posted on 11/9/05 at 04:58 PM |
pps - is there anything I can give you off my wire loom / switch gear that would better identify what I am talking about?
Deckman001
posted on 11/9/05 at 08:03 PM |
The switch gear will be stamped with the code for which ever application it is, that will help, that and the cable colours that you have in the loom
ready for the switch gear connections
Jason
[Edited on 12/9/05 by Deckman001]
stuartsavill
posted on 12/9/05 at 09:29 AM |
So... has anyone got a PIN Pattern, and function for each of the pins on the back of the various versions of switch gear
If anyone can supply these - I will put a matrix together, and post back up to this forum. If you want to e-mail me directly, please send to
stuart.savill@net-user.org
