Author: Subject: Megajolt
dave1888
posted on 12/9/05 at 04:20 PM Reply With Quote
Megajolt
The Zetec crank position sensor picks up TDC from the flywheel, can you use this set up for Megajolt, or do you need to fit a 36 toothed wheel setup
paulf
posted on 12/9/05 at 05:17 PM Reply With Quote
Yes just use the original flywheel trigger, a toothed wheel is only required on older engines or other makes.
Paul.
dave1888
posted on 12/9/05 at 07:02 PM Reply With Quote
Have you by any chance got a list of components to make up the ver 3 board yet Paul
paulf
posted on 12/9/05 at 09:16 PM Reply With Quote
Theres a printable list on the megajolt site, everything is available from farnells or RS.I havent made an ordering list up yet, as I need to sort what parts ive got and then order parts for 6 units.
I can flash the chip with the bootloader if you need one.
Paul
posted on 14/9/05 at 12:17 PM Reply With Quote
Paul.
As long as the flywheel trigger has 36-1 teeth!
dave1888
posted on 14/9/05 at 08:07 PM Reply With Quote
I ordered the chip at the same time as the board.
