Author: Subject: shes turning but no fire.
pointy
posted on 27/9/05 at 07:07 PM Reply With Quote
Ok those who have helped so far with wiring pre start....the quest moves on........I would like help....................which direction would the rotor arm be facing to be in position no 1 (on cap) with number 1 piston tdc and mark on pulley 4 degrees . ....side entry cap and imagine looking down on the cap....therefore 12 oclock would be arm facing top and 6 oclock facing oil filter..sorry if its 6 year old speak............I did get a flame from the exhast earlier on and thought oooooooops that s not right...crossflow engine...
andy p
gary gsx
posted on 27/9/05 at 07:22 PM Reply With Quote
you need too find out what position your valves are at it may be firing on no.4 instead no.1 so 4 would be on compression and 1 would be on exhaust hence the flame from pipe, timing out 180 degrees maybe
pointy
posted on 27/9/05 at 07:32 PM Reply With Quote
ok,
As dizzy was new i have no idea which way round so talk me thru working out to get it right.
thanks
andyp
gary gsx
posted on 27/9/05 at 07:41 PM Reply With Quote
Blimey long time since i worked on a crossflow if im wrong chaps just hola
Take off rocker cover, turn engine over till rockers on no 4 are rocking both rockers on no 1 should have a gap, engine firing on 1 fit dizzy, should be a notch on casing align rotor arm with that then do the leads to firing order
pointy
posted on 27/9/05 at 07:52 PM Reply With Quote
thanks
I shall give it a try tommorrow.
andy p
