ade
posted on 23/10/05 at 02:11 PM |
sierra front uprights
i have just got my plans from g.t.s for the sierra donor and was wondering what mods are needed to the front uprights,as i have facilitys to do the
work myself rather than send to g.t.s does anybody have any drawings or photographs. thanks adrian
posted on 23/10/05 at 02:21 PM |
the only mod is widening the bottom balljoint hole, to the correct size taper. I forget the exact dimensions, but if you search, dont believe the
first thing you read. It is often misquoted.
Allegedly, mk2 astra ball joints fit straight into the sierra hub.
dnmalc
posted on 23/10/05 at 09:55 PM |
The taper I believe is 14 degrees
Rorty
posted on 24/10/05 at 04:27 AM |
It sure is!
The taper is 1:8 which works out to 7.125016°. If you machine or ream the hole so the major diameter is Ø17.3mm you'll be good to go.
Cheers, Rorty.
