phelpsa
posted on 28/10/05 at 02:56 PM |
90mm Headlights / Driving lights
I'm looking for a pair of 90mm driving lights / headlamps to go in a headlights casing i've got. They have to have either a built in
sidelight or angel eye / halo ring around the edge and be E-marked. Does anyone have a pair or know where i can get some?
Adam
RazMan
posted on 28/10/05 at 04:39 PM |
I think the Hella jobbies that SVC sell are 90mm. Fairly positive that they have built in side light too.
Raz
phelpsa
posted on 28/10/05 at 05:55 PM |
£180 a pair is a bit over my budget
RazMan
posted on 29/10/05 at 08:28 AM |
In which case have a look at the Ring spotlights range. They do a small spotlight with angel eye rings. Not exactly sure about the size (must be
around 90mm though) bu they should do the trick.
edit ... they are 100mm
[Edited on 29-10-05 by RazMan]
Raz
phelpsa
posted on 29/10/05 at 10:46 AM |
I had a look at those in halfords, and the hole in the headlight casing is only 95mm
