Author: Subject: Wiring Megajolt to Bike Carbs
oliwb
posted on 14/11/05 at 09:56 PM Reply With Quote
I'm looking to fit bike carbs to my pinto and a megajolt with a TPS sensor....does anyone know what's the best type of sensor to buy? Ford or bike specific? And how is the best way to fit it to the carbs? I'm using Keihin carbs from a Kawasaki ZX7r....Cheers Oli.
paulf
posted on 14/11/05 at 10:02 PM Reply With Quote
I found Ford TPS sensors work fine and easy to obtain from a breakers, RS also do a neat potentiometer that can be used but it is about £16. Anything with a linear scale and between 5 and 10k ohms resistance would work ok.
Paul
[Edited on 14/11/05 by paulf]
big_wasa
posted on 14/11/05 at 10:05 PM Reply With Quote
See your last post m8.
regards warren
oliwb
posted on 14/11/05 at 10:11 PM Reply With Quote
Hi sorry but who are RS (rally sport or something similar?) What happens about the MAP using bike carbs don't you get difficulty with pulsating and the like? Map sensor would be easier on all fronts just worried it won't work as well?? Oli.
paulf
posted on 14/11/05 at 10:28 PM Reply With Quote
RS is RS components a large industrial supplier, just edited previous post as i meant Ford TPS sensor.
It is possible to link all four carbs by the vacuum take off points normally fitted and then use a pulse damper consisting of a small canister with a restrictor on the inlet or some cars use similiar devices in the vacuum line to ecu.
There has been lots of debate about whether tps or map is better but no definite answer as it depends on usage etc.
Paul.
caber
Hey folks Oli really needs to get this sorted out. If his megajolt don't work he'll be wanting the distributor he gave me yesterday back ( Thanks for that Oli!)
Caber
PS RS components have a good web ordering site for small orders url is <http://rswww.com/> pretty weird but works
[Edited on 11/14/2005 by caber]
oliwb
posted on 14/11/05 at 10:33 PM Reply With Quote
Cool cheers will check them out.....Oli.
oliwb
posted on 14/11/05 at 10:34 PM Reply With Quote
oh and Ps. your new distributor is safe with you.....bought most of the gear now so gotta finish it now! Oli.
paulf
posted on 14/11/05 at 10:52 PM Reply With Quote
Rs website see.
Rotary position sensor stock number 319-310. 5k reistance.£17.30.
Caber
oliwb
posted on 23/11/05 at 12:53 PM Reply With Quote
here we go again! - got a ford TPS sensor (thanks Warren) No obvious way of connecting it to the carbs so I'm gonna make up some sort of bracketry to attach it more directly to the pedal.....can anyone see any problems with doing this?? Also does the TPS have to go right through all its available travel to work properly or can full throttle be half way round on its scale?? Sorry but if it doesn't it'll make the job a whole lot easier....had a look at the RS one, unfortunately its full travel is 106 degrees which would make this job even harder! Thanks...Oli.
Schrodinger
posted on 23/11/05 at 01:11 PM Reply With Quote
Oli
I would attach it to the throttle spindle not the pedal.
The rotary action on the pedal will only be about 45 degrees at most whereas the throttle spindle will be nearer 135.
It will only need a plate fixing to the end of the carb for this to work.
Keith
oliwb
posted on 23/11/05 at 01:32 PM Reply With Quote
My bike carb spindle goes through just less than 90 degrees from fully closed to fully open, the ford sensor only travels about this same amount......Oli.
