Spriggsy
posted on 24/11/05 at 06:05 PM |
Speed sensor on type 9
Hello all.
I am using a type 9 gearbox from a 93 sierra, there is an electronic unit towards the rear of the box which I assume was a pick up for the sierra
injection system.
Does anyone know if this unit can be used as a VDO electronic speedo pick up?
Thanks.
John.
Avoneer
posted on 24/11/05 at 06:37 PM |
Are you sure that isn't the switch for the reverse light?
Pat...
Spriggsy
posted on 24/11/05 at 06:47 PM |
No Pat Its the pick up for the injection system, the speed sensor for the ecu on the original 1.8i sierra. It has 3 wires with a multiplug coming out
of it, the reverse switch has 2 pins on it.
John.
Dusty
posted on 24/11/05 at 08:09 PM |
I have VDO speedo and use the hall effect speedo sensor from a mondeo speedo cable to drive it quite happily. Couldn't find the sensor off a
type nine when I fitted it.
phoenix70
posted on 24/11/05 at 08:13 PM |
you can use it as a speed sensor, assuming you can calibrate your speedo to match the output. I have used one of these, it works, although I have
still to calibrate it properly (not with a VDO gauge though)
hope this helps, basically the wiring is + and earth plus a sensor wire, that goes to the speedo. ( I can't remember which is which off the
top of my head, I think it is brown - earth brown/yellow - live, and the other one is the signal wire to the speedo.... but don't quote me on
that)
Spriggsy
posted on 24/11/05 at 08:20 PM |
Cheers for the input lads.
Phoenix this sounds ideal, I'll give it a whirl. I think that calibrating the speedo will be no problem, thanks.
John.
Avoneer
posted on 24/11/05 at 10:37 PM |
Sorry mate, didn't mean to upset or offend, just checking that you knew there was another connection on their.
Pat...
Spriggsy
posted on 24/11/05 at 10:46 PM |
No worries Pat, no offence taken
John.
