Author: Subject: Fireblade Speedo Sensor / What output?
Howlor
posted on 29/11/05 at 09:52 AM Reply With Quote
I have a Fireblade RR-V motor with the electronic speedo. I am mounting a Acumen digital gear indicator so therefore need to attach this to the electronic speedo sensor. My question is that I am using an Acewell speedo with a magnetic trigger mounted to the prop, could I also use this for the Acumen or will I need to mount the original Fireblade sensor unit as well to the drive?
What output does the Fireblade sensor use?
Many thanks,
