New Topic New Reply
Author: Subject: Sierra column wires!!
stuey39
posted on 11/12/05 at 09:18 AM Reply With Quote
Hi all, can anyone tell me what the 2 brown wires that are on top of the sierra column above the connectors. They do appear to come from just below the hazzard button but not sure. There is also a single brown wire that goes to a spade connector just to the left of these wires, again I have no idea what this is for.
Many thanks
Stuart.
Avoneer
posted on 11/12/05 at 09:26 AM Reply With Quote
The two brown ones connect to two contacts in a small plastic casing on top of the column that make contact with the metal rings on the back of the steering wheel for the horn.
The other brown wire with the spade connection is the all important earth - make sure this is connected or it will cause you no end of trouble.
Hope that helps,
Pat...
stuey39
posted on 11/12/05 at 09:35 AM Reply With Quote
Thanks for your help, it makes for more sence now.
Deckman001
posted on 11/12/05 at 10:05 AM Reply With Quote
Sounds like they might be the Horn wiring ???, that and an earth as well
Get ya meter out and check em
Jason
New Topic New Reply
